41Alberto
Industrial
- Aug 21, 2014
- 3
We are building an ASME vessel with half-pipe jacket for cooling. Since it is a cyclic design, the weld between the jacket (4 mm thk) and the shell (16 mm thk) must be a full penetration weld. According to ASME code, can the weld shown below be considered a full-penetration fillet weld?
Vessel manufacturer arguments:
- Basically the ASME-Code requires a minimum attachment of the thinnest wallthicknes (either jacket or shell) – which is 4 mm in our case
- For cyclic load ASME code recommends (but it is a recommendation) to attach the coil completely. This does NOT MEAN having a full penetration weld of 4 mm, plus a fillet weld of 6,46 mm on the outside!
This is my understanding of a full-pen fillet weld:
Your comments are very much appreciated!
