foxtrot_67
So I have a vertical pressure vessel, where the shell has a half pipe on it (single coil, pic attached). Usually, I'd just do a Half Pipe Jacket calc as per Appendix EE, but this shell has holes on it, i.e. the half pipe sees the same pressure as the shell inside. Are there any UG guidelines that I can follow here? Any help is appreciated, thanks
