Hammer Beam 1
dik
25,822
Does anyone have links or reference articles on analysing and designing 'Hammer Beam' timberframe trusses?
thanks, Dik
Design
In order to give greater stature in the centre, the ordinary tie beam is cut through and the portions remaining, known as hammerbeams, are supported by curved braces from the wall. Hammerbeam roofs can exert considerable thrust on the walls that support them.[1]
Mike McCann
MMC Engineering
Motto: KISS
Motivation: Don't ask
Thanks, Mike...
I've already modelled it in Risa. The forces/stresses aren't as large as I thought they might be. The Vermnot timber link has a bit of an outline (page 1 of 4) for a typical connection design. Are you aware of a text that goes into some detail about timberframe connections? I have several books on them, but there is no detailed engineering information.
Dik
I have a Handbook for Engineers on the maximum design values for typical Timberpeg frame members. If you call them, you should be able to get one too, assuming they are still in business. It also has exploded sketches of the various connections. Dated April 26, 1999.
Timberpeg Design Services
Mike McCann
MMC Engineering
Motto: KISS
