I have terrible trouble using hard points on areas. Typically the meshing fails if there are more than a few points. After repeated attempts with different meshing parameters the model becomes corrupted. One symptom is that it starts creating hundreds of keypoints at 0,0,0 on its own. Also, the hardpoints cannot be deleted even if you delete the area.
I am contacting ansys on this. Please let me know of your experiences and send an example if you can
Much thanks
Much thanks
