irrigationguy
Agricultural
- Oct 27, 2023
- 1
Looking at installing a 24 or 30" Hdpe dr9 4710 line on top of ground. 4200 linear feet, 500' elevation. This will replace a buried steel pipe that has failed to due landslides that has z kinked a 20" steel pipe. Any advice how to anchor or hold the pipe from sliding/snaking too much? Will be pushing water up a hill, open discharge at the top. Also any advice on longevity of line on top of ground? Need this to last 50+ years. Ideas to hold pipe if that ground under it slides? Thanks in advance
