If u were to cool hydraulic oil using chilled water via a shell and tube heat exchanger. is there a real downside to pump the oil in the tubes and the water around them?
cause i feel like pumping water inside the tubes is better than pumping oil, propably even more cost-effective maybe...can someone confirm or refute this?
thnx
thnx
