EastEng1012
I am designing headwall with fairly large conduit opening (8-foot diamter). The headwall has wingwalls at 45-degrees. The headwall will need to extend about 3-4 feet above the conduit per the civil grading.
I am designing the headwall above the conduit to span horizontally to the wing walls to resist the lateral earth pressures. I figure I have to check the in-plane thrust from headwall reaction into the wing walls to rely on the wingwall support. I am curious as to how I should approach this check. Does the thrust get distributed purely horizontally along the length of wing wall and then check for resistance against sliding? Also would the wingwall (assuming it resisting sliding) behave similar to a shear wall for in-plane bending.
Or would the reaction distribute at an angle within the wingwall (like an internal strut) and have both a vertical and horizontal component (meaning part of the thrust would be resisted by both the wingwall footing in bearing and sliding friction)?
