W1987
Petroleum
- Apr 29, 2023
- 14
Hi everybody, I have a question. Thank you for your time.
We need to remove a complete weld on a shell that belongs to a pressure vessel. The removal will be performed by grinding.
We will remove both the weld metal and the heat-affected zone (HAZ).
Here’s the question: the HAZ on austenitic stainless steels is typically around 4 to 5 mm at most. However, some coworkers have told me that we need to remove one thickness from both sides of the weld. The plate thickness is 16 mm.
Do you know of any recommendations or standards about the width of the HAZ that needs to be removed? what are you experienced?
In my opinion, removing 16 mm from both sides of the weld seems excessive.
Again, thank you very much for your time.
