Hi All,
New in post to a heat exchanger company; where there's no other engineer to discuss/demonstrate. I come from pressure vessel background, though i've been in other industry [machine design] for several years so in need of a refresher!
Case in point; I'm to run through HTRI thermal software to establish a clients proposed tube length is fit/unfit.
provided information
Tube flow [3710 Nm3/hr] 93% o2, 5% Ar, 2% N2
inlet temp 148c
outlet temp 50.3c
inlet pressure 3.03 bara
pressure drop 6.9kpa
fouling resistance - 0.0005 ft2-hr-F/BT
design pressure 10 bar
design temp 200c
Shell side
propylene glycol 40/60 with water
inlet 42C
outlet -
inlet pressure 3 bara
pressure drop 69kpa
fouling 0.0005
design pressure 10 barg
design temp 93C
I'm correct in saying I cannot convert the Nm3/hr into Kg/S without specific volume or density of gas?
I'm correct in saying I either need to understand the required outlet temp OR available duty, to calculate the remaining factors?
Cheers, any tips appreciated.
inlet temp 148c
outlet temp 50.3c
design temp 200c
Shell side
inlet 42C
outlet -
pressure drop 69kpa
fouling 0.0005
design temp 93C
