Heat exchanger Tubesheet and tube material for SS 405/410S material
KD007
9
Hello All,
I am designing carbon steel heat exchanger however the tube and tubesheet material is specified as Type 405/410S on client dataset but I am not able to find equivalent grades in asme code.
As TP 410S is only available in plate material and TP 405 material is only available for tube material only in Asme part II d.
Kindly advise asme material in such situation for tube and tubesheet forging.
Thanks.
