MedicineEng
Industrial
Hi AlL:
I have to make a HVAC cursory analysis of an area that we are repurposing which will have a big increase on LED lighting quantities and power.
I was trying to get some information on how much actual input power is dissipated as heat in case of LED lighting, but a ggogle search gives me figures between 10% up to 60% heat.
This is a huge range and I'm a little bit confused on which number to follow to check if any upgrade to the HVAC system is required.
Any hints on where can I find accurate information on this?
What are you guys assuming in your projects?
