PEDARRIN2
- Oct 1, 2003
- 1,287
Trying to determine how quickly the water temperature in a partially full sanitary drainage pipe will drop from 180 F to 140 F.
The rationale is to determine where in the piping system I can transition from Cast Iron pipe to PVC when I have a discharge to the system from a boiler/water heater/dishwasher.
I am trying to come up with a "general" numerical model which can be used over different pipe sizes (2" to 4") and different pipe full fractions (25%, 50%, 66%).
Considerations/Issues
1. How to account for the partial flow in a pipe heat transfer equations. Do I use hydraulic radius for r? How do I account for heat transfer to the air space above the water line in the pipe? How do I account for the portion of the pipe wall that is not in contact with the water?
2. If I assume the flow is turbulent (which I am not sure I can since I have never tried with partially full pipe), how do I calculate the Reynold's number? Do I again use the hydraulic radius?
Any thoughts?
Any thoughts?
