MichielVZ
- Jun 25, 2019
- 8
My problem is as follows.
There is a plate of aluminium (500mm x 480mm x 100mm) that needs to be heated. The top surface of this plate needs to be heated to 200 degrees Celsius through the use of 4 (d-16 L-500mm 2.75kW) heating elements placed a the bottom of the plate. What i would like to know is, at the moment that the top surface reaches 200 degrees, what are the temperatures throughout the rest of the height of the plate? Assume that the 100mm is the height.
So far i have already calculated the required energy as roughly 11.6 mega Joules and the rate of heat transfer as 164.6 kW.
Any assistance will be greatly appreciated.
