Designer_82
What percent of the equipment kW is best to use when doing Heating/Cooling loading calculations?
For example, a millwork warehouse with CNC machines, cutting machines etc.
Given the nameplate of all that equipment, it adds up to 100kW. How much of that reasonably contributes to heat load... Meaning what would you enter in the software for "Electrical Equipment Wattage"?
Thank you
Thank you
