BronYrAur
- Nov 2, 2005
- 798
I have a heating hot water system with 2,500 GPM centrifugal pumps at a 90' head design condition. They are constant volume pumps serving a variable volume load of air handler coils. All coils have 2-way valves. At one time, a pneumatically controlled bypass valve was at the end of the line, but it has been removed.
I have been asked to install a new bypass valve at the end of the line to prevent dead-heading of the pumps. According to the manufacturer, i will need to size the valve for the pump minimum flow of 725 GPM. The customer wants a "self-controlled" valve with no pneumatics or electrical controls.
I am not sure what differential pressure i will normally see at the end of the line. Maximum would of course be dictated by the dead-head condition of the pump. Also, pump curve is relatively flat as it backed down toward the minimum flow (red line on the curve. see attached). Might be difficult to control.
Any thoughts or recommendations on how to handle this?
