Mstrux92
- Mar 21, 2020
- 10
Hello, I am designing a custom knife plate for some heavy timber beams. Typically, I would go with a proprietary hanger, but this case is unique. The Main Beam is (2) stacked 12x14 DFL beams, the side beam is a 10x10 DFL. The Side beam is centered in the stacked beam. The connection to the 10x10 must be concealed. I have attached a detail for my proposed connection. For calculations, I checked the connector capacity in the side beam, main beam, row/block tear out in main beam (still need to check side beam), and steel plate welds. I am also planning to check pullout of the connectors in the main beam. My connection must hold 5000 lbs snow load (ASD).
I greatly appreciate any feedback/discussion on my connection.
