KntBors
- Aug 30, 2010
- 1
I am working on a Dam Failure Analysis and attempting to utilize HEC-GeoRAS with ArcGIS (version 9.3.1). The actual stream length is over 10 miles long and in order to import the stream alignment into HEC-GeoRAS, you must digitize the alignment in ArcGIS. This involves re-drawing the entire 10 miles of stream in ArcGIS snapping from node to node. Does anyone know a faster way of completing this process?
thanks
