bernard1021
Hello everyone. Hope you're doing well today!
May I kindly ask if we can operate a reciprocating compressor without its non-slam check valve on its discharge line?
another question: is low capacity issue on a recip compressor is only limited to piston ring/liner failure? or is it always accompanied by faulty suction and discharge valves?
we cannot fully conclude failure on discharge and suction valves because we do not observe high discharge temperature. however, interstage pressure becomes higher than normal.
our initial findings that we have right now is a damaged non-slam type check valve on the discharge line.
hoping any help from anyone. Thanks
