About PWHT and after hydrotest welding
Hello Friends, I have some doubt about ASME Div 2 clause interpretation) for following issue facing one of my task. Due to some issue, We need to weld non-pressure(piping/platform cleats) after PWHT but before Hydrotest. Any one can confirm my understanding is correct?
1. Does ASME Sec VIII, Div.2 permit welding of 20 mm thick cleats (with weld size 12.6mm) directly onto 140 mm thick shell that has already been PWHT but before final Hydrostatic test?
(My interpretation, 1.Yes , Para. 4.2.5.6 (e) and Para. 6.11 Tables, Table 6.8 (a) (3) of ASME Sec.VIII Div.2)
2. Is there any requirement in ASME Sec VIII Div 2, that requires PWHT for sour / H2S service regardless of weld joint thickness?
(MY Interpretation, There is no such requirement in ASME Sec.VIII Div.2.)
3. If a reinforcement (RF) Pad is welded to the vessel shell and all subjected to PWHT, can cleats be welded to the RF Pad at a later date without the need for further PWHT (regardless of RF Pad thickness)?
(My interpretation, Yes Since the welding onto the pad is beyond the ASME code boundary.(Para. 1.2.3 (b) of ASME Sec.VIII Div.2)
4. Can the welding of the cleat onto the RF Pad (regardless of RF thickness) be done even after vessel Hydrotest?
(My interpretation, Yes Same as above no.3.)
