Hello
I have the below question could anyone advise me
Current Scope : Refer to P&ID no. DZ-HBR-01-WSX-PRO-PID-0001 Typical Wellhead, 2" chemical injection designed by using heavy thickness 316SS pipe and special flanged ends valve high rating 10,000 psi
Propose to proceed: Redesign by using 1/2" 316SS tubing and thread (NPT) ends valve. No welding, NDT, hydro test, flange, gasket, bolting and valve rating 10,000psi required for this option which can save cost for materials and construction.
Change material chemical injection line size and type from pipe to SS tubing for oil wells is it Ok or NO
Thank you in advance
