Hello I want to use the pytho
R.S
11
Hello
I want to use the python script (generateEventSeries.py) to convert the G-Code data into Abaqus input files for additive manufacturing. Where can I find this file?
Thank you for your help
thread799-473915
It should be available in the Knowledge Base article "Abaqus/CAE Plug-in Utility for Additive Manufacturing Process Simulation" but most likely it requires customer account.
Thank you for your answer, but generateEventSeries.py is not available in the mentioned article. I would be so grateful if you share the direct link to this file.
Thank you
Since the AM plug-in is now built into Abaqus, it seems that DS removed the possibility to download it with other files from their websites and left only the workshop files attached to that KB article. But you may still find this script on 3DSwym.
