Help in solidworks motion analysis
himeshlem79
Aerospace
Nov 3, 2020
3
Anyone know how the angular displacement independent variable works in motion analysis, I have to give torque to a shaft with its angle as an independent variable, I found an option to use one of the results we define like angular displacement or velocity as the independent variable, but after using it I'm getting unpredictable results and very fast rotation, compared with the ame value of torque given with time as independant variable. This is very time-consuming to troubleshoot, so any help will be much appreciated.
You might want to move this to the Solidworks forum 559 I think you will get a better answer there. then please delete this thread.
B.E.
You are judged not by what you know, but by what you can do.
