Asisraja D
Hi
We need nitrogen plant for our API plant for vacuum breaking and we have selected the flow rate around 20 Nm3/hr but we have no data apart from this.
Does anyone help me what are the parameters to be considered for nitrogen plant selection for this application if any guide available please share me here.
i tried this file i have attached here but still not clear in this.
flow rate is calculated based on the reactors capacity but we could not select which generation system will be suitable whether membrane type or PSA method? i have googled it to know what is best but i need experts solution in this so please help me. thanks for all of you.
"Strive for perfection in everything you do. Take the best that exists and make it better. When it does not exist, design it." - Sir Henry Royce
