help needed
Ali768
Nuclear
GB
Hi
I am a beginner in MATLAB. I have to develop a code in which I have to read two text files separately containing a column vector each (the vector size can be between 300-400, containing the decimals numbers). Once data is read as txt files I have to perform the following mathematics on it
A(0) = x1*y1 + x2*y2 + x3*y3 + …… + xN*yN
A(1) = x1*y2 + x2*y3 + x3*y4 + …… + xN*yN+1
A(2) = x1*y3 + x2*y4 + x3*y5 + …… + xN*yN+2
A(J) = x1*yJ + x2*yJ+1 + x3*yJ+2 + …… + xN*yN+J
Where x1, x2,...., xN is the first column vector file and y1,y2,...., yN+2 is the second vector file.
The result of the above mathematics will be third column vector file of A(0), A(1), A(2), ….. A(J) which can be saved a output txt file.
Any help in code development will be highly appreciated as I tried to do it myself but due to beginner still finding hard to get it right.
ali
