andyl9063
Computer
- Jan 9, 2020
- 13
I had some water intrusion issue.
Plan is :
1. 2 layers of waterproof membrane
2. 1 Drainage dimple mat
3. Mat sits on drainage pipe
4. Cover pipe with 2 layers of sock, then fill with sand on top
5. Backfill rest with clay soil.
The issue I'm running into is the last part of foundation has a 12 inch drop so drainage pipe has a 12 inch drop. The red circle is day-light that I could drain out to, but its 12 inch up hill.
I know there will be a way for water to go out, but would it struggle uphill and water sitting there near foundation with perforated holes.
Is there another solution? Or I was thinking of a catch basin with a lower inlet and higher outlet that drains out to daylight? Will that work ?
Plan is :
