Dear All,
For a design of a new pump, it is highly recommended to keep room for future expandability. In fact API 610 section 6.1.4 is also indicating the head rise from rated condition by 5 % with regards to potential impeller increase.
In absence of available vendor data during the early design stage, if we want to design the pump motor for the maximum end of curve operation at maximum impeller in order to ensure that no pump replacement would occur in future upon upgrading pump impeller, is there any rule of thumb which can be used in conjunction with affinity law when estimating the motor power demand for the maximum impeller. If we know a typical rule for correlating the rated impeller with the maximum impeller within a horizontal OH pump type, we can estimate a preliminary prorated value of upgraded impeller end of curve motor power load based on the approximation from the calculated motor power for the rated impeller.
Are there any rules of thumb available for the above?
