Does anyone have a spreadsheet already coded to perform a HGL analysis? The one I created is faster then doing it by hand but still cumbersome when I need to edit things. Can hydrocad accurately determine HGL's?
Thanks!
I recommend that you use your own as you will know how it was coded. You may need to spend some time to "clean" it up so it's not so cumbersome. I hesitate using other's spreadsheets; sometimes it takes longer to verify them than it would take to create it from scratch. If you know visual basic, you can make it pretty sweet over time.
I have two spreadsheets that I created that are linked. The first is the hydrology and spread calculations and preliminary pipe sizing which is linked to my storm drain spreadsheet. I do not use them as much anymore because of INROADS STORM & SANITARY OR STORMCAD.
