dreamschool
- Jun 20, 2003
- 29
I noticed failures for some heat number ,,,and when we re-rest another plate from the the same heat ...some times it pass the test!!
Can we have different result for the same heat number for HIC test.
we used sloution A and the same procedure !!! Can i have answer for my concer and explination about how these result can be different from test to another
One more thing, the cemical compostion test is OK...sulfur is less than 0.01!!!!
Always the plate passes the HIC...after forming the pipe and take sample from the pipe and conduct HIC test...it failed...
it is strange for me ...i could not understand this...any explination???
i wrote this in steel forum...but it may related to the Metal and Metallurgy
