rockman7892
Are there any issues with applying an HRG on MV system at 4.16kV? I'm used to seeing HRG reserved for LV (480V) system with MV systems typically having LRG.
With an HRG on an MV system is it typically applied at the same 10A range as on LV systems (assuming that is above system charging currents)?
Can the system continue to stay in service with a ground fault similar to LV systems or must the ground fault be removed via localized tripping on MV systems?
Do these HRG systems on MV typically have the same pulsing detection system with dedicated CT's / ammeters on feeders to aid in ground fault location?
