Eng_Director
Good morning everyone,
I'm in charge of a small 22 story building with an ongoing hot water issue that I can't seem to resolve. It's a hotel that has approximately 250 guestrooms, each with a shower/tub and sink. It's supplied from the bottom up from 2 hot water tanks (each averaging around 175F internal) and a pump to each of three zones. We are clocking in around 140F to 150F at each zone with a balancing valve for each stack of rooms. The issue I'm having is that we are constantly getting hot water complaints from a variety of rooms around the building. Everything on the BMS is showing good, but individual rooms in no apparent pattern are getting ice cold water when the shower is running hot. This can be as many as 5 to 10 rooms a day or none at all. It tends to happen more frequently in the morning when the demand is highest, but we're not getting any errors for heat or pressure on the risers at each zone. I'm at a loss for what could be the issue. Usually these problems will resolve themselves within the hour, but it's creating a lot of stress for our customers and our team. I've brought out some plumbers before to take a look at our system and they can't figure out what the issue is. So I'm hoping some peers might have some more insight on what I can look at.
Kind Regards,
Justin
Kind Regards,
Justin
