Hilti-Concrete Strength 1
dik
25,681
Hilti used to have HAS anchor strengths for concrete embedment with a couple of concrete strengths. I can only locate information based on steel strength. Does anyone have a link?
You can download its catalog here, Link. Or use its software.
Thanks guy... I had them, but don't know where I filed them, and couldn't find them...
Save the download with file name start with "Hilti", so easier to find the next time.
That's actually what I did... and created a folder with only Hilti stuff in it...
Next time do a "key word" search on your computer (a stipe bar says "Type here to search" on lower left of PC window). It will list all files contain the word you typed. So you don't need to browse through all your folders (just too many, I believe, because it happens to me too. :)
Have you tried using Hilti's 'Profis' software (browser based) for anchor design, or Simpson's 'Anchor Design' software. Both are free, and do a good job automatically interpolating all of the data for you (edge distance, spacing, concrete strength, embedment, anchor type, hole cleaning method, etc).
Have both Profis and Simpson's... Thanks... I'm in the process of doing an SMath program for anchors... still be awhile... pretty complex.
