Hello everyone,
I have found myself in such a problem using hole feature, commonly in other CAD platforms as Solid Edge and Solid Works you can include holes that you don't want to depict in part level but in assembly level, eg. when you have a weldment assembly that need to be re-drilled after fabrication.
I tried using normal hole feature, and then select the face where i need to locate the instance but seems to have no result,
I'm not sure if i'm using it the wrong way because this is the first time i'm using assembly cut and hole feature at the same time to represent my instances.
What is the process you often use in order to depict this?
Below is attached the warning that i have every time that chose to run it that way.
