Hole Table - Related Parts
BrittToolEngineer
Aerospace
Greetings:
When performing a Hole Table, after I select all the holes that are needed in the hole table, I get a dialog box with the following information/question: Hole Table requires some feature data to be fully loaded. Do you want to load the related parts? Yes or No. I'm not sure how to answer this. Can someone expand on how the answer to this question effects the hole table?
Brent
To be able to get the full information on your holes, NX needs to have the PART fully loaded. You can safely answer this question with yes.
Only effect you might have is that you will have to wait a bit for the part(s) to get fully loaded.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
