Hole with fit
MANox
PL
I have question about Hole:
If I want create Hole with fit (p.ex. H7) I need to select Screw Clerance and select posiontion from my own list with interesting tolerance.
And it's work - in drawing, when I select Hole and Thread Callouts dimension is with my tolerance (strange - it's doesn't work with PMI).
My question is: what If I want add tolerance to the diameter from outside my list?
Is it possible to add tolerance to other diameter and dimension will know: this is diameter with special fit?
Best regards
MANok
NX2027 - NX2406
TC14 - TC2412
