AgMechEngr
Agricultural
- Jul 22, 2022
- 63
I am working on a home addition that will add 200 sq ft off the gable end wall side of the house. The existing home is a 4" slab on grade with masonry stem walls. At this time, I do not know if the slab is floating or poured into the stem walls. The addition will be a bathroom and an extension of an existing laundry room. The laundry room portion is what I am concerned about. Since this will create a room that spans the old slab with the new, I do not know how seamless of a transition I can reasonable create. I certainly would not recommend tile to be installed, but engineered hardwood has a chance.
My current solution is a masonry stem wall on the three exterior sides. Dig down to the existing footing and drill and epoxy #5 dowels to tie into the new slab, which will be a thickened slab on the interior. It is common in this area for the top course of masonry walls to be a L header to serve as the form for the slab.
More info, this is in south Georgia and the soils are not expansive.
What do you all think? I think it all depends on how the original slab was poured at the stem wall where the addition will begin. The easiest solution is to suggest a partition wall with a pocket door at the transition from the new slab to the old, so the flooring could have a more natural transition.
