I inspected a house on the beach in NJ this past week, which was a 1-story dwelling with a basement, constructed fully of masonry block. When I went into the basement, there was a horizontal crack about 36" above the basement slab (and near outside grade level) which propagated through the mortar joint and extended around all four perimeter walls at the same elevation. What was most interesting was that the mortar looked like it was being pushed out and when I took a vertical profile of each wall, it was not leaning or displaced inward, which is usually what I expect when I see these types of horizontal cracks. Additionally, I believe I ruled out a settlement issue from the level measurements that I took. When I removed a dislodged section of mortar that was sticking out from the wall, I found what looked like a piece of corroded steel between courses. The house was constructued in 1940 but could this be some type of bond beam or other reinforcement that could have corroded because it was near grade level and then pushed out the mortar due to corrosion volume expansion? I'll attach some pictures below. Also, any thoughts on a possible fix? I'm thinking of having them scrape out the oxidation from both interior and exterior sides, epoxy sealing it, and then repointing but I've never come across this before.
