asalisbury
- Mar 6, 2024
- 9
I am working on a feasibility study for a high pressure horizontally oriented HIP (hot isostatic press) and need some help with the thought experiment and general design. This machine will need to have the following characteristics - Pressure: 15,000psi | Temp: 800°C | Length: 84in. | Diameter: 32in.
I have contacted a few vendors and it seems as though horizontal orientation of HIPs makes cooling the gas and electrical feedthroughs near impossible without significant investments into research and development. The new idea is to design a hinge on the base of the HIP so it can be loaded horizontally and then rotated to a vertical position for the pressing operation. Are there existing designs that use a similar method for horizontal loading? Can you think of a better way to load it horizontally and then move it into a vertical orientation? Any help is much appreciated!
asalisbury
EIT Mechanical
Aerospace Composites
asalisbury
EIT Mechanical
