IRL
- Jan 18, 2009
- 5
Hi Guys,
We have installed a 250Kw 4pl motor on a pump application, the motor is running at 47hz and drawing 350 amps, the nameplate details are as follows: 250Kw 4pl 400-690 D/Y 50Hz Class F, B temp rise, IP55, VSD rated with 3 x PTC's. This motor is working in a large machine room with an ambient of 13 deg C at present outside temp at the moment between -5 to + 2. The bearing on the drive end is a cylindrical roller, the NDE is a insulated ball. The roller at the DE is measuring 78 deg at the bearing cap and the NDE bearing is 23 deg C, around the top of the fins behind the terminal box (roughly in the middle) the temp is 67 deg. The motor is cooled by its own fan, the vsd has not gone out on over temperature or over current and it is working away fine but we are concerned by the temp of this NDE bearing, i checked the grease plate and it is not over full, when we stopped it for a few hours the temp dropped and it gradually creeped back up to 78 deg over the coarse of a few hours as the motor warmed up. Any comments would be welcome.
