hot keys triggered in sketcher
multicaduser
Industrial
Jan 29, 2013
261
When typing an expression or formula into an input for dimension in the new sketcher, whenever a letter that is a hotkey is pressed it cancels the input and jumps to the hotkey function.
Example, this is similar to what I wanted to type.
nth(variable_name,{1,2,3})
what happens is when the "t" in "nth" is pressed it jumps to the trim curve function.
Is there a setting that can be changed to stop this or is it a bug? This only started happening in 2306.
NX 2306 Windows 10
Just to piggyback on this, I've had it happen when adding GD&T within a note. When adding letters for the datums, I get kicked into the Arc menu, Circle, and Line. I've even been booted into Modeling mode from Drafting.
This has been going on sporadically for at least a few years nor. We're on 2306 right now, but it has happened in the past few versions too. As usual, when I ask someone over to my desk to show them it never does it.
Mike
