what is best practice to test a leak suspected hot oil coils for crude storage Buffer tank?.
the coils pipe is A106 Gr B NPS 3" seamless pipes, used to heat up tank store heavy crude oil with 450,000 barrels 80 diameter, 15M maximum liquid height.
the tank have 3 coils (loops) supplied from 6 inch main header.
- heating media is therminol55.
- operating pressure 9 bar, maximum temperature 250 deg.C.
- the heating system is a loop from horizontal vessel to heater, to tank coils and back.
- the coils is welded joints which changed from flanged joints after last internal inspection.
- the last internal inspection is before 5 years.
- we test every coil and monitor vessel level suspected in 2 coils and isolated ,
- the tank is in-service now and will not going to make internal inspection soon.
- suspect of leak because of noticed decrease in level of heating medium in hot oil horizontal vessel.
- Crude is sweet not corrosive.
but we need to confirm that
is pressure test with therminol ok? and what pressure we need to use is it MOP or design pressure?.
and what hold time we have to use is 24 hours or 4 hours?
