I am working on updating the hot tap procedure for my company and one of the comments on updating is that the question of using a backing ring always comes up. I can find very little on the use of backing rings for hot tapping.
Question 1:
Should backing rings ever be recommended? If so, what would be the circumstances?
Question 2:
The valves are to be tested to be "leak free." Should I specify that they be seat tested per API 598, or is there another type of leak test that would be more appropriate?
Thanks in advance.
Question 1:
Question 2:
Thanks in advance.
