Dear Fellows,
We have noticed that there is some up-down movement of two pipes coming from a 3-phase separator. The movement is only seen if someone shake or move the pipes, otherwise the pipes are stable. The parameters for the pipes are as following:
Size 2 inch, SMLS Pipe, SCH 80, ASTM A 106 Gr. B, Operating temperature 38 degrees celsius, operating pressure ATM, Insulated, Fluid: Hot Water Inlet and Outlet pipes.
Do you think that we should add another support after the descending elbows (See photo)? If yes, how we can support such request?
Thanks for support.
Thanks for support.
