JStructsteel
- Aug 22, 2002
- 1,446
Got a house that has a stacked stone foundation. The best I can tell there is movement outward from the wall. I recommended that it be replaced.
Any ideas other than total replacement. Would some piers in front of it and a grade beam do any good (stop lateral movement?)
I did an inspection, no crawl space identified. Its only approx. 12 feet (3ft on a corner, then 8ft perpendicular)
Any other ideas short of supporting the structure and removing?
