How and if at all can I make a click and count block?
AndresKr
1
Hi, I have some lines and I would like to add a counter at the bottom of them? So if I add or a remove a line, the number sequence updates. Right now I have to make a note at each line and manually change it's number * this is prone to errors.
For example I added a the red line, added a textbox/block under it and it would write 6. Ideally it should change the sequence as well, but it's ok even if it just writes the next number in the +1 sequence. If I delete a line, all numbers go -1.
Is it even possible?
 https://files.engineering.com/getfile.aspx?folder=d7057d1f-3a04-4b7b-9735-205972417d95&file=Kuvatõmmis_2023-08-17_134736.png
