Roleci
- Jan 29, 2020
- 8
Hello;
We have a 125 MVA YNd11 380/33 kV transformer on the field.Low voltage side is connected to ground through a zig zag grounding transformer without a resistor.I want to calculate the x/r ratio of a L-G fault in order to find the decaying time of DC component.As far as I know there is no zero sequence impedance on delta side.So in this case should I only use the positive and negative sequence impedances of the power transformer together with zero sequence impedance of the grounding transformer to calculate the x/r ratio of fault ?
Thanks in advance.
Grounding transformer zero sequence impedance is 10+j90 ohm.
Thanks in advance.
