How can I explain what second Piola-Kirchhoff stress is? 1
tugni925
107
From "
"The components of the first Piola-Kirchhoff stress are the forces acting on the deformed configuration, per unit undeformed area. They are thought of as acting on the undeformed solid . The second Piola-Kirchhoff stress has no obvious physical interpretation."
Excerpt is from "Numerical investigation of stiffness and buckling response of simple and optimized infill structures". I want to explain how second Piola-Kirchhoff stress comes into play here. I am not sure how to explain it when it has no physical interpretation, is it all just mathematical equations?
The second PK tensor connects the loads in the initial, undeformed condition to the initial geometry.
The simplest explanation I can think of is that PK2 describes the relationship between initial loads and geometry at time zero. The value of PK2 is that it is symmetric - i.e. its utilization is less computationally difficult.
