How can I let the mesh elements horizontal edges parallel with each other in ABAQUS?
Raniel Albuquerque
Petroleum
Jun 18, 2019
4
I'm trying to generate a mesh with two bias, upward and leftward, as you can see in the picture. But, when I generate the mesh, the elements horizontal edges aren't parallel.
Any thoughts how can I solve that?
Best regards!
Which meshing algorithm and technique do you use ? Try another one, it should work for mapped mesh. And make sure that settings of these 4 biased edge seed distributions are the same.
