How can i override a dimension in drafting?
JavadM
119
Hi
i have a drawing with some dimensions and have to replace dimension texts with letters such as A, B and so on.
in dimensions setting and "text>format" it is possible to change the dimension but i cant get rid of diameter and radius symbol and letters
how can i override dimension entirely?
best regards
NX 12
In the settings of your Radial or Diameter dimensions, Set symbol to User Defined and then remove the Symbol to Use entry.
Ronald van den Broek
Senior Application Engineer
Winterthur Gas & Diesel Ltd
NX9 / TC10.1.2
Building new PLM environment from Scratch using NX12 / TC11
i appreciate ronald
thanks
You can also do this by:
menu -> edit -> annotation -> text
then select dimension and change it by letter.
With best regards
Michael
@niedzviedz
The question was about removing the R or the diameter symbol.
You can also do this with your suggestion but then you need to replace the symbol with a space.
The solution I proposed you can remove it completely.
NX9 / TC10.1.2
Sorry, I misunderstood the post :)
With best regards
Michael
