I'm trying to create a custom block in Simscape that convert energy from pressurized water into a torque. Here is my code:
component pelton_turbine
% Ce composant calcule le couple généré par l'eau sur la turbine.
Déclaration des ports
nodes
H = foundation.hydraulic.hydraulic; % Port hydraulique
R = foundation.mechanical.rotational.rotational; % Port mécanique rotatif
end
Déclaration des paramètres
parameters
eta = {0.85, '1'}; % Rendement de la turbine
rho = {1000, 'kg/m^3'}; % Densité de l'eau
r = {0.5, 'm'}; % Rayon moyen de la roue
g = {9.81, 'm/s^2'}; % Gravité
end
Déclaration des variables internes
variables
Q = {0, 'm^3/s'};
T = {0, 'N*m'}; % Couple généré
H_head = {0, 'm'}; % Hauteur d'eau équivalente
end
branches
% Débit hydraulique pris directement depuis le port H
Q : H.q -> *;
end
equations
% Calcul de la hauteur d'eau (pression convertie en mètre de colonne d'eau)
H_head == H.p/ (rho * g);
% Calcul du couple généré par l'eau
T == {eta * rho * Q * r * sqrt(H_head * 2 * g), 'N*m'};
% Transmission du couple à l’axe mécanique
R.t == T;
end
end
My problem is that I have this error when I try to build my component:
Invalid use of a value with unit cm^3*kg/(m*s^2) when attempting to bind a unit.
The value to which the unit is bound must not have an associated unit.
• In pelton_turbine.pelton_turbine (line 36)
eta = 0.8500
Q = {[1x1 double], 'cm^3/s'}
r = {0.5000, 'm'}
H_head = {[1x1 double], 'm'}
g = {9.8100, 'm/s^2'}
I don't get why the flow rate (Q) is in cm^3/s instead of m^3/s and I don't know how to change it. Do you have an idea ?
Since Q is a through variable I can't define his unit. I also tried changing the units in the Configuration Parameters in my .slx file (I changed cm^3/s into m^3/s for the flow rate) but it didn't have any effect on my .ssc file and I keep getting the error.
Nils
nodes
end
parameters
end
variables
Q = {0, 'm^3/s'};
end
branches
Q : H.q -> *;
end
equations
R.t == T;
end
end
eta = 0.8500
r = {0.5000, 'm'}
Nils
