Follow along with the video below to see how to install our site as a web app on your home screen.
Note: This feature may not be available in some browsers.
thanks for shring the document. Its wonderfulI would like to add my points to the above valuable, answers;
- The base plate thk. is very important factor . The rule of thumb for me is to compare the flange thk. of the column with base plate thk. The resistance
of the column is limited by its slenderness and so , the minimum stiffness of the column base depends relative slenderness of the column.
- The rotational stiffness of the footing is another factor. A small size spread footing may not satisfy rigid conn. assumption even the column to base plate and to footing is rigid enough .
- The following doc. ( could be a reference at Eurozone ) worth to look :
It's generally less costly to thicken the plate than add stiffening gussets.Unless you have stiffening gussets (which are expensive)
